You can use the Copy settings in the Make a Copy or Batch Export Settings dialog box to make copies of the and associated . You can save the files to the destination of your choice.
Why copy files? You can do any of the following:
| • | transfer photos from a memory card or other storage device |
You can also choose to import at the same time as you copy, saving you a step.
When you copy with a batch, all the master files that you select are copied as well as the sidecar files that contain data about any versions, edits, and metadata.
Some of settings for copying are the same as other batch settings. For more information, see Understanding export settings. The following settings are only in the page for the Copy tab.
Output Name and Location — same as the controls described in Output Name and Location settings, with the addition of:
| • | Delete Original files — deletes the image that you are copying after it has been copied successfully to the new location. All image files and associated are copied to the location specified in the Destination section at the top of the dialog box. |
Import into Catalog — enable this check box to import the images into a Corel AfterShot Pro catalog after the images are copied. The following importing options are available:
| • | Import Location — choose a catalog location |
| • | Prompt — enable the check box if you want to see a dialog that asks for a catalog location when you first send images to this batch. It imports all images to the location you choose. |
| • | Select a folder button — if you did not enable Prompt, you can click this button to choose a folder. |
| • | Keywords — lets you add keywords that will be added to all the images as you import. |
| • | Apply Presets — lets you apply presets to the images as you import them. For more information about presets, see Presets. |
© 2014 Corel Corporation. Note: The availability of features depends on the version of the software you have.
