This Preferences page allows you to view, add or remove custom crop settings.
| • | Opacity of cropped-out area — sets how dark the removed portion of the image will be shown when the cropping tool is enabled. |
| • | Grid sections — sets the number of lines or sections to show in the crop window. Setting this to 3 will create "rule-of-thirds" lines to help visualize your crop, and setting it to 2 will show grid lines through the center of the crop frame. |
| • | Show frame — lets you set when to show the crop frame: Always, Never, or only when Dragging the crop window. |
| • | Show grid — lets you set when to show the grid: Always, Never, or only when Dragging the crop window. |
| • | Show Crop dimensions — lets you hide or display the size and location of the crop in pixels within the crop window. |
| • | Add New — opens the Crop Size dialog box so you can create new settings for a crop preset. |
| • | Edit Current — opens the Crop Size dialog box so you can edit or rename crop preset settings. |
| • | Remove Current — removes the current, highlighted crop preset from the list. |
© 2014 Corel Corporation. Note: The availability of features depends on the version of the software you have.
