You can read (open and view) or write (save and export) to a wide range of file formats.
RAW files from a wide array of digital cameras are supported as well as JPEG and TIFF files. The table below lists many supported cameras, but for a list that includes the latest cameras, please visit www.aftershotpro.com.
Nikon |
Coolpix A, D40, D40x, D50, D60, D70, D70s, D80, D90, D100, D200, D300, D300s, D600, D610, D700, D750, D800, D800e, D810, D4, D4s, D3s, D3x, D3, D2x, D2h, D2xs, D2hs, D1, D1h, D1x, D3000, D3100, D3200, D3300, D5000, D5100, D5200, D5300, D7000, D7100, Df, Nikon 1 AW1, Nikon 1 J1, Nikon 1 J2, Nikon 1 J3, Nikon 1 J4, Nikon 1 S1, Nikon 1 V1, Nikon 1 V2, Nikon 1 V3, P330, P6000, P7000, P7800 |
Canon |
EOS: D30, D60, 10D, 20D, 30D, 40D, 50D, 60D, 70D, 5D, 5D Mark II, 5D Mark III, 6D, 7D, 7D Mark II, 1D, 1D Mark II, 1D Mark IIn, 1D Mark III,1D Mark IV, 1Ds, 1Ds Mark II, 1Ds Mark III, 1Dx, 100D, 300D, 350D, 400D, 450D, 500D, 550D, 600D, 650D, 700D, 1000D, 1100D, 1200D, Kiss F, Kiss X6i, Kiss X7, Kiss X7i, Kiss X70, M, Rebel SL1, Rebel T4i, Rebel T5, Rebel T5i Powershot: G1 X, G1 X Mark II, G2, G3, G5, G6, G7X, G9, G10, G11, G12, G15, G16, S40, S45, S50, S60, S70, S90, S95, S100, S110, S120, Pro1, SX1, SX50 HS, SX60 HS Canon sRAW and mRAW formats |
Olympus |
E-1, E-3, E-5, E-10, E-20, E-30, E-300, E-400, E-410, E-420, E-450, E-500, E-510, E-520, E-600, E-620, E-M1, E-M5, E-M10, E-P1, E-P2, E-P3, E-P5, E-PL1, E-PL1s, E-PL2, E-PL3, E-PL5, E-PL7, E-PM1, E-PM2 C5050z, C5060wz, C7070wz, C8080wz, SP-310, SP-320, SP-350, SP-500uz, SP-510uz, SP-550uz, XZ-1, XZ-2, OM-D E-M5 Stylus 1 |
Pentax |
K20D, K200D, K100D Super, K10D, K100D, K110D, *ist DS2, *ist D, *ist DS , *ist DL, *IST DL2, K2000, K-m, K-7, K-x, K-3, K-5, K-5 II, K-5 IIs, K-r, K-01, K-30, K-50, K-500, MX-1, Q, Q7, Q10, 645D, 645Z |
Samsung |
GX-1L, GX-1S, GX-10, GX-20, NX5, NX10, NX11, NX100, NX200 |
Sony |
NEX-A7, NEX-A7 Mark II, NEX-A7R, NEX-A7S, NEX-3, NEX-3N, NEX-5, NEX-5R, NEX-5N, NEX-5T, NEX-6, NEX-7, NEX-C3, NEX-F3, a33, a35, a37, a55, a55V, a57, a58, a65, a77, a77 II, a99, a100, a200, a230, a290, a300, a330, a380, a390, a350, a450, a500, a550, a560, a580, a700, a850, a900, a3000 (ILCE-3000), a5000 (ILCE-5000), a5100 (ILCE-5100), a6000 (ILCE-6000), DSC-R1, DSC-RX1, DSC-RX10, DSC-RX100, DSC-RX100 II, DSC-RX100 III, DSC-RX1R |
Panasonic |
DMC-GM1, DMC-GX7, L1, L10, LF1, LX1, LX2, LX3, LX5, LX7, LX100, FZ8, FZ18, FZ28, FZ30, FZ35, FZ38, FZ40, FZ45, FZ50, FZ150, FZ200, FZ1000, G1, G2, G3, G5, G6, G10, GF1, GF2, GF3, GF5, GF6, GH1, GH2, GH3, GH 4, GM1, GM5, GX1, GX7, TZ60, ZS40 |
Leica |
DIGILUX 3, V-LUX 1, V-LUX 2, V-LUX 3, V-Lux (TYP 114), D-LUX 2, D-LUX 3, D-LUX 4, D-LUX 5, D-Lux (TYP 109), M8, M9, X1, X2, Digital MODUL-R8, Digital MODUL-R9, C, M (TYP 240), T, Monochrome |
Minolta |
DiMAGE A1, DiMAGE A2, DiMAGE 7, DiMAGE 7i, DiMAGE 7Hi, MAXXUM 5D, MAXXUM 7D, DYNAX 5D, DYNAX 7D, DiMAGE A200, ALPHA-5 DIGITAL, ALPHA SWEET DIGITAL, Alpha-7 Digital |
Kodak |
DCS Pro 14n, DCS Pro 14nx, DCS Pro SLR/c, DCS Pro SLR/n |
Ricoh |
GX-100, GX-200, GR, GR Digital II, GR Digital III, GXR, GXR P10 |
Fuji |
HS50EXR, X-A1, X-E1, X-E2, X-M1, X-Pro1, X-S1, X-T1, X10, X20, X30, X100, X100S, X100T |
TIFF Images |
Up to 250 megapixels (40960 px on the long side for 64-bit; 20480 px on the long side for 32-bit), RGB colorspace (CMYK, grayscale or TIFFs with alpha channel not supported) Some adjustment tools are more limited or are not available (Highlight Recovery) with TIFF files. |
JPEG Images |
Up to 250 megapixels (40960 px on the long side for 64-bit; 20480 px on the long side for 32-bit), RGB colorspace (CMYK or grayscale not supported) Some adjustment tools are more limited or not available (Highlight Recovery) with JPEG files |
Corel AfterShot Pro can save images to the file formats listed in the table below.
File Type |
Filename Extension |
Bit Depth |
Comments |
JPEG |
JPG, JPEG |
8 Bit |
JPEG files are the most common image files, and are ideal for sharing on the web, by email, or for sending to online printing facilities. JPEG files are limited to 8-bit color, and are compressed by a user-selectable amount. Corel AfterShot Pro uses a 0-100 scale to set the JPEG quality level. A setting of 100 produces a very large file that has no compression artifacts. A setting of 50 will produce visible artifacts, but will also result in a much smaller file. The default setting is 80 for proofs and 90 for full size JPEGs. |
TIFF |
TIF, TIFF |
8 Bit or 16 Bit |
TIFF files use only lossless compression, ensuring that 100% of the detail from the original image is preserved. TIFF files can be either 8–bit or 16–bit, and produce very large file sizes. |
About image compression
Image Compression is the process of lowering the image file size so you can store more photos in a fixed amount of space. There are two types of compression:Lossy or Lossless.
Lossy Compression results in the loss of data during the compression process. This means that the compressed image will lack some detail and image information. Small amounts of lossy compression (for example, JPEG compression set at a level of 90 or higher) produce images that are very similar in detail and image quality to the original image. More aggressive compression settings (for example, compression numbers like 50 or 70) produce noticeable compression artifacts and detail loss.
Lossless Compression reduces the file size with no loss of data, and therefore no loss of image quality.
© 2014 Corel Corporation. Note: The availability of features depends on the version of the software you have.
