Align and distribute nodes
CorelDRAW lets you quickly align and distribute nodes in one or more curves.
First, you need to choose a reference point. The reference point can be the bounding box of the selection, the page edge or center, the closest grid line, or a specified point.
The nodes in a curve (1) are left-aligned relative to the bounding box of all active nodes (2), the page edge (3) or center (4), the closest grid line (5), or a specified point (6).
After you set a reference point, you can choose an alignment option. You can align nodes to the left, right, top, or bottom, or along a horizontal or vertical axis.
The active nodes in a curve (top left) are aligned to the left (1), right (3), top (4), bottom (6), and along a vertical (2) and horizontal (5) axis relative to the bounding box of the selection.
You can align nodes from different curves.
The selected nodes from the two curves are aligned relative to a specified point.
When you align nodes in a selection, the alignment is based on the average of the bounding area of the active nodes. CorelDRAW aligns nodes based on the order in which they appear along a curve rather than on the order in which you select them because it can be time-consuming to select nodes one at a time in complex objects with hundreds of nodes. You can change the order of the nodes by reversing the direction of the curve object.
Distributing nodes adds equal spacing between them horizontally or vertically. You can distribute nodes within the bounding box that contains them or over the drawing page.
Nodes are distributed horizontally (1 and 3) and vertically (2 and 4) within the bounding box that surrounds them (1 and 2) and over the entire page (3 and 4).
CorelDRAW distributes nodes based on the order in which they appear along a curve.
From top to bottom: The nodes in a curve (top left and top right) are distributed horizontally (middle) or vertically (bottom) based on the order in which the nodes appear along the curve.
To prevent blurry edges in curve objects designed for web use, you can align the object nodes with the pixel grid. This feature realigns object nodes to position them correctly on the pixel grid.
Align nodes with the pixel grid to prevent blurry edges.
To align nodes
Back to Top
1 Select the nodes with the Shape tool .
2 In the Align and Distribute docker (Window Dockers Align and Distribute), choose a reference point by performing a task from the following table.
To
Do the following
Align nodes relative to the bounding box of the active nodes
Click the Active nodes button in the Align nodes to area.
Note: When you select nodes along a curve, the nodes are aligned based on the order in which they appear along the curve. To change the direction of a curve, click the Reverse direction button on the Shape tool property bar.
Align nodes with the page edge
Click the Page edge button in the Align nodes to area.
Align nodes with the page center
Click the Page center button in the Align nodes to area.
Tip: To align nodes with the page center, make sure that the Align horizontally button and Align vertically button in the Align area are enabled.
3 In the Align area of the docker, click one of the following buttons:
Align left — to align nodes to the left
Align horizontally — to align nodes along a vertical axis
Align right — to align nodes to the right
Align top — to align nodes to the top
Align vertically — to align nodes along a horizontal axis
Align bottom — to align nodes to the bottom
You can also
Align a node with the closest grid line
Click the Grid button in the Align nodes to area.
Align a node with a specified point
Click the Specified point button in the Align nodes to area, and type values in the Specify coordinates boxes.
Tip: You can also specify a point interactively by clicking the Specify point button , and clicking in the document window.
Set an alignment option for text nodes
In the Text area, choose one of the following options:
First line baseline — aligns text by the baseline of the first line
Last line baseline — aligns text by the baseline of the last line
Bounding box — aligns text by its bounding box
You can also align nodes within the active selection, vertically and horizontally, by clicking the Align nodes button on the property bar, and enabling one or more alignment options in the Node align dialog box.
To distribute nodes
Back to Top
2 In the Align and Distribute docker (Window Dockers Align and Distribute), click one of the following buttons in the Distribute nodes to area to choose the area over which the nodes are distributed:
To selected — distributes the nodes over the area of the bounding box that contains them
To page — distributes the nodes over the drawing page
3 To distribute nodes horizontally, click any of the horizontal distribution buttons.
4 To distribute nodes vertically, click any of the vertical distribution buttons.
Since nodes have no real width or height, clicking any horizontal or vertical distribution button places equal space between the nodes along a horizontal or vertical axis, respectively.
To distribute nodes by a specified distance
Back to Top
2 Click Object Align and Distribute Align and Distribute.
3 In the Distribute to area, click the By object spacing button .
4 Type values in the H and V boxes to set the distance between objects horizontally and vertically.
5 To distribute nodes horizontally, click any of the horizontal distribution buttons.
6 To distribute nodes vertically, click any of the vertical distribution buttons.
To align nodes with the pixel grid
Back to Top
1 Select a curve.
To view the results, click View Pixels, and adjust the zoom level to 800% or higher.
3 Click Align with Pixel Grid.
