Select text
CorelDRAW lets you select text to edit specific characters or modify it as an object. For example, you can select specific characters to change the font or select a text object, such as a text frame, so you can move, resize, or rotate it.
To select a text object
Back to Top
To
Do the following
Select artistic text
Using the Pick tool , click the artistic text.
Select a text frame
Using the Pick tool , click the text frame.
You can use the Pick tool to select multiple text objects. Hold down Shift, and click each text object.
To select text for editing
Back to Top
To
Do the following
Select specific characters of artistic or paragraph text for editing
Using the Text tool , drag across the text.
Select a text frame for editing
Using the Text tool , click the text frame.
