Spirals
You can draw two types of spirals: symmetrical and logarithmic. Symmetrical spirals expand evenly so that the distance between each revolution is equal. Logarithmic spirals expand with increasingly larger distances between revolutions. You can set the rate by which a logarithmic spiral expands outward.
You can change the default settings of the Spiral tool so that all new spirals you draw have the properties you want.
A symmetrical spiral (left) and a logarithmic spiral (right)
To draw a spiral
Back to Top
1 In the toolbox, click the Spiral tool .
2 Type a value in the Spiral revolutions box on the property bar.
3 On the property bar, click one of the following buttons:
Symmetrical spiral
Logarithmic spiral
If you want to change the amount by which the spiral expands as it moves outward, move the Spiral expansion factor slider.
4 Drag diagonally in the drawing window until the spiral is the required size.
You can draw a spiral from its center outward by holding down Shift as you drag.
You can also draw a spiral with even horizontal and vertical dimensions by holding down Ctrl as you drag.
To choose default settings for the Spiral tool
Back to Top
1 Click Tools Options Tools.
2 In the left pane of the dialog box that appears, click Spiral.
3 Change the settings you want.
