Transform nodes
You can shape objects by stretching, scaling, rotating, and skewing their nodes. For example, you can scale the corner nodes of a curve object to enlarge the curve object proportionally. Also, a curve object or parts of a curve object can be rotated in a counterclockwise or clockwise direction.
Stretching nodes
To stretch, scale, rotate, or skew nodes
Back to Top
1 In the toolbox, click the Shape tool .
2 Select a curve object.
3 Select the nodes along the curve that you want to transform.
4 On the property bar, click one of the following buttons:
Stretch or scale nodes
Rotate or skew nodes
5 Drag a set of handles to transform the nodes.
