Copy and cut segments
You can copy and cut curve segments, and then paste them as objects, making it easy to extract subpaths or create adjacent shapes with similar contours.
A curve segment was copied (left) and then pasted as an object (right).
To copy or cut a curve segment
Back to Top
1 Select the curve object.
2 Using the Shape tool , select the nodes on a curve segment, and then press one of the following:
Command + C to copy the curve segment
Command + X to cut the curve segment
Command + D to duplicate the curve segment at a specified offset distance
To paste the curve segment, press Command + V.
