Copy, duplicate, and delete objects
CorelDRAW provides you with several ways to copy objects. When you no longer need an object, you can delete it.
You can cut or copy an object to place it on the Clipboard and paste it into a drawing or another application. Cutting an object places it on the Clipboard and removes it from the drawing. Copying an object places it on the Clipboard but keeps the original in the drawing.
Duplicating an object places a copy directly in the drawing window and does not use the Clipboard. Duplicating is faster than copying and pasting. When an object is duplicated, there is a distance between the duplicate and the original object along the x and y axes. This distance, known as duplicate offset, can be changed in the Preferences dialog box.
You can apply a transformation, such as rotating, sizing, or skewing, to the duplicate of an object while keeping the original object intact. If you decide that you want to keep the original object, you can delete the duplicate.
You can create multiple copies of objects simultaneously, while specifying their position, without using the Clipboard. For example, you can distribute object copies horizontally, to the left or right of the original object; or you can distribute copies of objects vertically, below or above the original object. You can specify the spacing between copies of objects, or you can specify the offset at which copies of objects are created in relation to each other.
You can use other methods to create copies of objects quickly, without using the Clipboard. You can use the plus sign (+) on the numeric keypad to place a copy of an object on top of the original object, or you can create copies instantly by pressing the Spacebar or Control-clicking while dragging an object.
To cut or copy an object
Back to Top
1 Select an object.
2 Click Edit, and click one of the following:
Cut
Copy
You can also cut or copy an object by Control-clicking the object and clicking Cut or Copy.
To paste an object into a drawing
Back to Top
Click Edit Paste.
You can use this procedure to paste an object from another application.
To paste an object from an unsupported file format, or to specify options for the pasted object, click Edit Paste Special.
To duplicate an object
Back to Top
1 Select an object.
2 Click Edit Duplicate.
Duplicating an object is useful for creating cuttable drop shadows for devices such as vinyl cutters and plotters.
You can also duplicate a selected object by pressing Command+ D.
To change the default duplicate offset, click Layout Document Preferences. On the General page, type values in the Horizontal and Vertical boxes.
Offset values of 0 place the duplicate on top of the original.
Positive offset values place the duplicate up and to the right of the original.
Negative offset values place the duplicate down and to the left of the original.
To create copies of an object at a specified position
Back to Top
1 Select an object.
2 Click Edit Step and Repeat.
3 In the Step and Repeat inspector, type a value in the Number of copies box, and click Apply.
To
Do the following
Distribute copies of objects horizontally
In the Vertical settings area, choose No offset from the Mode list box. In the Horizontal settings area, choose Spacing between objects from the Mode list box. To specify the spacing between object copies, type a value in the Distance box. To place the object copies to the right or left of the original, choose Right or Left from the Direction list box.
Distribute copies of objects vertically
In the Horizontal settings area, choose No offset from the Mode list box. In the Vertical settings area, choose Spacing between objects from the Mode list box. To specify the spacing between copies of objects, type a value in the Distance box. To place the copies above or below the original, choose Up or Down from the Direction list box.
Offset all copies of objects by a specified distance
In the Horizontal settings and Vertical settings areas, choose Offset from the Mode list box, and type values in the Distance boxes.
Multiple copies of an object are offset by a specified distance.
To create copies of objects quickly
Back to Top
1 Select an object by using the Pick tool .
2 Press the Spacebar while rotating or transforming the object.
You can also
Place a copy of an object on top of the original
Press the plus sign (+) on the numeric keypad.
Create a single copy by using a mouse or stylus.
While moving, rotating, or transforming the object, Control-click and then release both mouse buttons.
To transform the duplicate of an object
Back to Top
1 Select an object.
2 Click Window Inspectors Transform.
3 Choose the settings you want in the Transform inspector.
4 Type 1 in the Copies box.
5 Click Apply.
You can clear a transformation by selecting an object and clicking Object Clear Transformations.
To delete an object
Back to Top
1 Select an object.
2 Click Edit Delete.
To retrieve a deleted object, you must use the Undo command. For more information, see Undo, redo, and repeat actions.
You can also delete an object by selecting it and pressing Delete.
