Crop and erase objects
You can crop and erase portions of objects.
Crop
Cropping lets you quickly remove unwanted areas in objects and imported photos, eliminating the need to ungroup objects, break linked groups apart, or convert objects to curves. You can crop vector objects and bitmaps.
Cropping objects
When cropping objects, you define a rectangular area (cropping area) that you want to keep. Object portions outside the cropping area are removed. You can specify the exact position and size of the cropping area, and you can rotate and resize it. You can also remove the cropping area.
You can crop only selected objects without affecting other objects in a drawing, or you can crop all objects on the drawing page. In either case, the affected text and shape objects are automatically converted to curves.
Erase
CorelDRAW lets you erase unwanted portions of bitmaps and vector objects. The Eraser tool works just like a pencil eraser, removing any part of the image over which you click and drag. If you want to erase only portions of a specific object, you have to select it. When no object is selected, the Eraser tool removes any part of the drawing over which you drag. For information about selecting objects, see Select objects. Erasing automatically closes any affected paths and converts the object to curves. If you erase connecting lines, CorelDRAW creates subpaths rather than individual objects. You cannot erase objects with contours, blends, drop shadows, block shadows, and extrusions.
When working with a pen or stylus, you can use pressure to vary the size of the eraser nib. If your pen or stylus supports tilt and bearing, you can use these features to vary the flatness and rotation of the eraser nib. You can also set fixed values for the tilt angle and bearing angle so that the flatness and rotation of the nib remain the same.
You can use your stylus to vary the size and flatness of the eraser nib.
You can also choose default settings for the Eraser tool such as the default size of the eraser nib. Objects created as a result of erasing have their nodes automatically reduced; however you can choose to disable this setting.
Delete
You can also delete virtual line segments, which are portions of objects that overlap each other. For example, you can delete a loop in a line that crosses over itself, or loops in line segments in which two or more objects overlap.
Deleting virtual line segments
To crop an object or imported photo
Back to Top
1 Select the object or imported photo that you want to crop.
You can select one or more objects. If no objects on the drawing page are selected, all objects in the drawing will be cropped.
2 In the toolbox, click the Crop tool .
3 Drag to define a cropping area.
4 Double-click inside the cropping area.
You can also
Specify the exact position of the cropping area
Type values in the Crop position boxes on the property bar, and press Return.
Specify the exact size of the cropping area
Type values in the Crop size boxes on the property bar, and press Return.
Rotate the cropping area
Type values in the Angle of rotation box.
Remove the cropping area
Click Clear.
Objects on locked, hidden, Grid, or Guides layers cannot be cropped. Also, you cannot crop OLE and Internet objects, rollovers, or the content of PowerClip objects.
During cropping, affected linked groups, such as contours, blends, and extrusions, are automatically broken apart.
You can move, rotate, and size the cropping area interactively as you would any object. To move the cropping area, drag it to a new position. To size the cropping area, drag any of its handles. To rotate the cropping area, click inside, and drag a rotation handle .
You can remove the cropping area by pressing Esc.
To erase an image area
Back to Top
1 Perform a task from the following table.
To
Do the following
Erase an area in a drawing
Deselect all objects.
Erase portions of an object
Select the object.
2 Do one of the following:
When using a mouse, click the Eraser tool in the toolbox.
When using a stylus, flip the stylus to automatically switch to erase mode.
3 Drag over the area that you want to erase.
You can also
Change the size of the eraser nib
Type a value in the Eraser thickness box on the property bar, and press Return.
Change the shape of the eraser nib
Click the Round nib or the Square nib button on the property bar.
Vary the width of the eraser nib
Click the Pen pressure button on the property bar to enable it.
The maximum width of the nib is determined by the value specified in the Eraser thickness box.
If you are using the mouse, press the Up arrow or Down arrow to simulate changes in pen pressure and change the width of the eraser nib.
Vary the flatness of the eraser nib
Click the Pen tilt button on the property bar to enable it.
Flatten the eraser nib by setting a fixed value for pen tilt
Click the Pen tilt button on the property bar to disable it, and type a value in the Tilt angle box.
You can specify a value between 15 and 90. The lower the value, the flatter the nib.
Vary the rotation of the eraser nib
Click the Pen bearing button on the property bar to enable it.
Rotate the eraser nib by setting a fixed value for pen bearing
Click the Pen bearing button on the property bar to disable it, and type a value in the Bearing angle box.
You can specify a value between 0 and 359.
Maintain all the nodes of the area being erased
Disable the Reduce nodes button on the property bar.
When you erase portions of objects, any affected paths are automatically closed.
You can erase straight lines by clicking where you want to start erasing, and then clicking where you want to finish erasing. Press Command if you want to constrain the line’s angle.
You can also erase an area of a selected object by double-clicking the area with the Eraser tool.
To choose default Eraser settings
Back to Top
1 Click CorelDRAW menu Preferences Tools.
2 Click Eraser in the left pane of the dialog box that appears.
3 Type a thickness value in the Thickness box to set the size of the eraser nib.
4 Enable or disable the Auto-reduce nodes of resulting objects check box.
To delete a virtual line segment
Back to Top
1 In the toolbox, click the Virtual segment delete tool .
2 Move the pointer to the line segment you want to delete.
The Virtual segment delete tool snaps upright when positioned properly.
3 Click the line segment.
You can also
Delete multiple line segments at one time
Drag a marquee to enclose or intersect all target segments.
Delete a virtual line segment that intersects with a curve
Hold down Option, and drag to draw a curve.
Weld line segments
Hold down Shift, click the two overlapping end points. You can also hold down Option + Shift, and drag to marquee select the overlapping nodes.
Deleting multiple virtual line segments
