Edit styles and style sets
You can edit a style or style set either by changing its attributes in the Object Styles inspector, or by changing the attributes of an object linked to the style or style set, and then applying these changes to the style or style set.
You can also edit a style or style set by copying attributes from an object to the style or style set.
You can override style attributes. When you override an attribute, it is no longer related to the style definition, and changes to the style do not affect the object until you remove the override.
To edit a style
Click
Window
Inspectors
Object Styles.
In the
Object Styles inspector, open the
Styles folder, and select a style.
In the style properties area of the
Object Styles inspector, modify the attributes you want.
To edit a style set
Click
Window
Inspectors
Object Styles.
In the
Style Sets folder, and select a style set.
Click the
Add or remove style button
next to the style set, and click the style type that you want to add or remove from the style set.
Check marks appear next to the style types that are included in the style set.
Object Styles inspector, you can edit the styles that are included in the style set.
To edit a style or style set by editing an object
Using the
Pick tool
, select an object that has a style or style set applied to it.
Click
Object
Properties.
In the
Properties inspector, edit the object properties.
4
In the document window, Control-click the object, choose
Object Styles from the context menu, and choose
Apply to Style.
The new attributes of the object replace the attributes of the styles or style sets associated with this object.
To edit a style or style set by copying properties from an object
Click
Window
Inspectors
Object Styles.
Drag an object from the document window over a style or style set name in the
Object Styles inspector.
You can also copy the properties of an object to a style or style set by Control-clicking the style or style set in the Object Styles inspector, choosing Copy Properties From, and then clicking an object in the document window.
To override a style attribute
Using the
Pick tool
, select an object that has a style applied to it.
Click
Object
Properties.
In the
Properties inspector, edit an object attribute defined by a style.
The source indicator next to the attribute changes from green with a vertical line
to orange with a horizontal line
, showing that the object attribute is no longer defined by the style.
To remove a style override, do one of the following:
Click the orange source indicator
, and choose
Revert.
In the document window, Control-click the object by using the
Pick tool
, choose
Revert to Style.
