You can feather the edges of vector and bitmap objects. Feathering gradually increases the transparency along the edges of objects making objects blend perfectly into the background.
Feather the edges of a bitmap to make it blend seamlessly into your composition.
Soften the edges of vector objects by using the Feather effect.
You can specify the width of the feathered section of the object and the transparency gradient you want to use.
