Formatting codes
You can insert formatting codes, such as em dashes and nonbreaking spaces. In some programs, formatting codes are also known as "symbols." The following table lists the available formatting codes and their corresponding keyboard shortcuts.
Formatting code
Keyboard shortcut
Nonbreaking space
Command + Shift + Space
Tab
Tab
Column break or text-frame break
Command + Return
Em dash
Option + -
En dash
Option + Shift + -
Nonbreaking hyphen
Command + Shift + -
You can find and replace formatting codes. For more information, see To find text and To find and replace text.
To insert a formatting code
Back to Top
1 Using the Text tool , click to place the cursor where you want to insert a character or space.
2 Click Text Insert Formatting Code, and choose a formatting code from the menu.
The Insert Formatting Code menu is unavailable when the Text tool is not active.
You can insert a character not listed in the Insert Formatting Code menu by clicking Text Glyphs and clicking the character in the Glyphs inspector.
