Import files
You can import (place) files created in other applications. For example, you can import an Adobe Portable Document Format (PDF), JPEG, or Adobe Illustrator (AI) file. You can import a file and place it in the active application window as an object. You can also resize and center a file as you import it. The imported file becomes part of the active file. You can also import a bitmap as an externally linked image. When you import a linked bitmap, edits to the original (external) file are automatically updated in the imported file.
While importing a bitmap, you can resample it to reduce the file size, or crop it to eliminate unused areas of the image. You can also crop a bitmap to select only the exact area and size of the image that you want to import.
When you import a file from an earlier version of CorelDRAW that contains text in a language different from the language of your operating system, you can use code page settings to ensure that object names, keywords, and notes saved with the file are displayed correctly.
To import a file into an active drawing
Click
File
Place.
Choose the folder where the file is stored.
If necessary, you can search for a file by using the search box. You can search for such things as file name, title, subject, author, keyword, comment, bitmap name, object name, and so on.
If the file contains text in a language different from that of your operating system, choose the corresponding option from the
Select code page list box to ensure that object names, keywords, and notes are correctly displayed.
These options are not available for all file formats.
4
Click
Place, and do one of the following:
Click the drawing page to maintain the dimensions of the file and position its top-left corner where you click.
Drag on the drawing page to resize the file. The import cursor displays the dimensions of the resized file as you drag on the drawing page.
Press
Return to center the file on the drawing page.
Press the
Spacebar to place the file in the same position as it was in the original file (CDR and AI files only).
Active snapping options are applied to the imported file.
Link to a bitmap externally instead of embedding it
Click Options, and then click Import as externally linked image check box.
If you want to display a list of the linked images, click Window Inspectors Sources.
Merge layers in an imported bitmap
Enable the Combine multi-layer bitmap check box.
Enable the Extract embedded ICC profile check box to save the ICC profile to the color folder where the application is installed.
This option is not available for all file formats.
Check for watermark or copyright information
Enable the Check for watermark check box.
Use the default settings for the filter instead of opening the dialog box
Click Options, and enable the Hide Import filter dialog check box.
Preserve layers and pages in an imported file
Click Options, and enable the Maintain layers and pages check box. If you disable the check box, all layers are combined into a single layer.
Select the pages to import when importing multi-page TIFF documents
In the Import TIFF dialog box, enable an option in the Select the page(s) to import area.
This option is available only for the TIFF file format.
Open only part of an image
In the Load partial file dialog box, type the range of frames to open in the Load frames box.
Not all importing options are available for all file formats.
You can import multiple files. Hold down Shift and click to select consecutive files in a list. Hold down Command and click to select non-consecutive files.
To import a bitmap as an externally linked image
Click
Window
Inspectors
Sources.
In the
Sources inspector, click the
New linked image button.
Browse to the drive and folder where the image is stored.
5
Click in the workspace to place the image.
Click the Update linked image button.
Break the link to an externally linked image
Click the Break link button.
