CorelDRAW lets you size and scale objects. In both cases, you change the dimensions of an object proportionally by preserving its aspect ratio. You can change the dimensions of an object by specifying precise values or by changing the object interactively. When you scale an object, you change its dimensions by a specified percentage.
The anchor point of an object, also known as "object origin," remains stationary when you resize the object by typing values in the Object size boxes on the property bar. If you want to change the object origin, click a point on the Object Origin button on the property bar.
You can also size an object by clicking Window Inspectors
Transform, clicking the Size button and then typing values in the Transform inspector.
The object origin, also known as "anchor point" or "reference point," can be the center of an object or any one of the object’s selection handles. The object origin remains stationary when an object is scaled by typing values in the Scale factor boxes on the property bar.
You can also scale an object by dragging a corner selection handle.
