Corel programs support the following color depths when you import Wavelet
Compressed Bitmap (.wi) files: 256-shade (8-bit) grayscale, and 24-bit RGB.
Corel programs support the following color depths when you export to the Wavelet
Compressed Bitmap file format: 256 shade (8-bit) grayscale, 24-bit RGB.
The Wavelet Compressed Bitmap file format supports Wavelet compression. It also
supports a minimum image size of 16 pixels and a maximum size of 2,048 pixels.
