Application window
When you launch CorelDRAW, the application window opens containing a drawing window. Although more than one drawing window can be opened, you can apply commands to the active drawing window only.
The CorelDRAW application window appears below.
Circled numbers correspond to the numbers in the following table, which describes the main components of the application window.
Part
Description
1. Toolbox
A docked bar with tools for creating, filling, and modifying objects in the drawing
2. Title bar
The area displaying the title of the currently open drawing
3. Menu bar
The area containing pull-down menu options
4. Toolbar
A detachable bar that contains shortcuts to menu and other commands
5. Update text toolbar
A temporary toolbar that allows you to update legacy documents in order to edit the text using the CorelDRAW X6 text controls.
6. Drawing window
The area outside the drawing page bordered by the scroll bars and application controls
7. Property bar
A detachable bar with commands that relate to the active tool or object. For example, when the text tool is active, the text property bar displays commands that create and edit text.
8. Docker
A window containing available commands and settings relevant to a specific tool or task
9. Rulers
Horizontal and vertical borders that are used to determine the size and position of objects in a drawing
10. Document palette
A dockable bar that contains color swatches for the current document
11. Document navigator
The area at the bottom left of the application window that contains controls for moving between pages and adding pages
12. Drawing page
The rectangular area inside the drawing window. It is the printable area of your work area.
13. Status bar
An area at the bottom of the application window that contains information about object properties such as type, size, color, fill, and resolution. The status bar also shows the current cursor position.
14. Navigator
A button at the lower-right corner that opens a smaller display to help you move around a drawing
15. Color palette
To toggle between displaying and hiding the status bar, click Window Toolbars Status bar.
To toggle between displaying and hiding the rulers, see To hide or display the rulers.
