The following object properties can be modified for symbol instances. If a symbol contains multiple objects, all objects in the symbol instance are treated collectively as a single object, just as if they were grouped.
Can be modified on the property bar. For more information, see Position objects.
Can be modified on the property bar. For more information, see Size and scale objects.
Percentage is relative to the symbol definition. Can be modified on the property bar. For more information, see Size and scale objects.
For more information, see Skew and stretch objects.
Can be modified on the property bar. For more information, see Rotate and mirror objects.
Can be modified in the Summary section of the Properties inspector. Can also be modified on the property bar. For more information, see To wrap paragraph text around an object, artistic text, or a text frame.
Can be modified on the property bar. For more information, see Change the order of objects.
Most objects in CorelDRAW can be converted to symbols, with the following exceptions.
