The transform effects let you transform the color and tone of an image.
The Deinterlace effect (Effects
Transform
Deinterlace) lets you remove lines from images. For more information, see Transform color and tone.
The Invert Colors effect (Effects
Transform
Invert Colors) lets you reverse the colors of an image. Inverting an image creates the appearance of a photographic negative. For more information, see Transform color and tone.
The Posterize effect (Effects
Transform
Posterize) lets you reduce the number of tonal values in an image to remove gradations and create larger areas of flat color. For more information, see Transform color and tone.
The Threshold effect (Effects
Transform
Threshold) lets you specify a brightness value as a threshold. Pixels with a brightness value higher or lower than the threshold appear as white or black. For more information, see Transform color and tone.
