After you find the image you need in a local, network, or Cloud folder, you can place it into your project as an embedded or linked object. When inserting a vector graphic, you can place it at the original position where it was created relative to the page.
You can open an image and edit it in its associated application. To find the images you like quickly, you can tag them as favorites. In addition, you can view and change the properties of an image. For example, you can change its title, add new keywords, and delete existing keywords. When you no longer need an image, you can delete it.
You can also insert a file into an active document as an embedded object by dragging the file from the viewing pane to the active document.
You can also insert a file into an active document by Control-clicking the file in the viewing pane and choosing a Place command.
You can also insert a file into an active document from the Tray inspector.
You can’t edit files that have been shared with you on the Cloud.
Control-click a thumbnail, and click Properties. In the Properties dialog box, do any of the following:
