There are two types of vector effects: effects, such as bevels, blends, contours, and extrusions, which can be applied only to vector objects; and effects, such as envelopes, drop shadows, inner shadows, block shadows, lenses, perspective, and mosaics, which can be applied to both vector and bitmap objects.
A vector effect (drop shadow) is applied to a bitmap (left) and vector object (right).
The following table provides a quick reference of vector effects.
Lets you add 3D depth to a graphic or text object by making its edges appear sloped (cut at an angle)
For more information, see Create bevel effects.
Lets you create a progression in shape and size from one object to another. Blends are often used for creating realistic shadows and highlights in objects.
For more information, see Blend objects.
For more information, see Add block shadows.
Lets you create 3D effects and cuttable outlines for outputting to devices such as plotters, engraving machines and vinyl cutters
For more information, see Contour objects.
For more information, see Add drop shadows and inner shadows.
For more information, see Shape objects by using envelopes.
For more information, see Create extrusions.
For more information, see Impact effects.
Lets you change how an object area beneath the lens appears, not the actual properties and attributes of objects
For more information, see Apply lenses.
For more information, see Apply perspective.
For more information, see Bitmap mosaics (PhotoCocktail effect).
For more information, see Vector mosaics (Pointillizer effect).
