Adobe Photoshop (PSD)
The Adobe Photoshop (PSD) file format is the native bitmap file format for Adobe Photoshop.
To import an Adobe Photoshop file
Click
File
Import.
Locate the folder in which the file is stored.
Choose
PSD - Adobe Photoshop (*.psd; *.pdd) from the list box next to the
File name box.
Resample a graphic while importing
Crop a graphic while importing
To export an Adobe Photoshop file
Click
File
Export.
Locate the folder in which you want to save the file.
Choose
PSD - Adobe Photoshop from the
Save as type list box.
4
Type a filename in the
File name list box.
6
In
Convert to bitmap dialog box, adjust the width, height, resolution, color mode, or any of the other settings.
![*](images/note.svg)
You can export to an image with a transparent background.
Adobe Photoshop (PSD) technical notes
Importing a PSD file
Monotone, grayscale, duotone, 48-bit RGB, and up to 32-bit CMYK images are supported.
Some layer effects cannot be imported. (Gradient map adjustment layer is imported without Noise, Opacity stops, and Dither.)
Imported layers using the Darken Color and Lighten Color blend modes map to the If Darker and If Lighter merge modes, respectively. For more information about working with merge modes, see
Merge modes.
Files that contain spot color channels are imported as multichannel (DeviceN) bitmaps.
Exporting a PSD file
This format supports 1-bit black-and-white and up to 32-bit CMYK color images.
Spot color channel information is preserved in the exported file.
