Align and distribute objects
CorelDRAW lets you precisely align and distribute objects in a drawing.
You can align objects with each other and with parts of the drawing page, such as the center, edges, and the closest grid line. You can also align objects with a specified point by entering its exact x and y coordinates. You can align objects by their edges (left, right, top or bottom) or by their centers.
Distributing objects automatically adds spacing between them based on their width, height, and center points. You can distribute objects so that their center points or selected edges (for example, top or right) appear at equal intervals. You can also distribute objects so that there is equal space between them. You can distribute objects over the extent of the bounding box surrounding them or over the entire drawing page. In addition, you can distribute objects by specifying the distance between them.
Scattered objects (left) are vertically aligned and equally distributed (right).
To prevent blurry edges in objects designed for web use, you can align the objects with the pixel grid. This feature realigns the nodes or edges of the object to position them correctly on the pixel grid.
Align objects with the pixel grid to prevent blurry edges.
To align objects
Click
Object
Align and Distribute
Align and Distribute.
In the
Align and Distribute docker, choose a reference point by performing a task from the following table:
Align an object with a specific object
Click the Selected objects button ![](../Shared_graphics/align-to-active-object.svg) .
If you select the objects one at a time, the last object selected is the reference point for aligning the other objects. If you marquee select the objects, the object that is positioned in the upper-left corner of the selection is used as a reference point.
Align an object with the page edge
Click the Page edge button ![](../Shared_graphics/align-edge.svg) .
Align an object with the page center
Click the Page center button ![](../Shared_graphics/align-center.svg) .
To align the center of the object with the page center, make sure that the Align center horizontally button ![](../Shared_graphics/align-horizontal.svg) and Align center vertically button ![](../Shared_graphics/align-vert.svg) in the Align area are enabled.
Align an object with the closest grid line
Click the Grid button ![](../Shared_graphics/align-grid.svg) .
Align an object with a specified point
Click the Specified point button ![](../Shared_graphics/align-specified-point.svg) , and type values in the X and Y boxes.
You can also specify a point interactively by clicking the Specify point button, and clicking in the document window.
4
In the
Align area of the docker, click one of the following buttons to use an object edge or center for aligning.
Align left ![](../Shared_graphics/align-left.svg)
— to align the left edges of objects
Align center horizontally ![](../Shared_graphics/align-horizontal.svg)
— to align object centers along a vertical axis
Align right ![](../Shared_graphics/align-right.svg)
— to align the right edges of objects
Align top ![](../Shared_graphics/align-top.svg)
— to align the top edges of objects
Align center vertically ![](../Shared_graphics/align-vert.svg)
— to align object centers along a horizontal axis
Align bottom ![](../Shared_graphics/align-bottom.svg)
— to align the bottom edges of objects
To align objects from their outlines, enable the
Use object outline check box.
Set an alignment option for text objects
Before clicking one of the alignment buttons described in the previous step, click one of the following buttons in the Text area:
• First line baseline ![](../Shared_graphics/align-first-line.svg) — aligns and distributes text by the baseline of the first line
• Last line baseline ![](../Shared_graphics/align-last-line.svg) — aligns and distributes text by the baseline of the last line
• Bounding box ![](../Shared_graphics/align-to-bounding-box.svg) — aligns and distributes text by its bounding box
![*](images/tip.svg)
You can also align objects with another object quickly, without using the Align and Distribute docker, by clicking Object
Align and Distribute and clicking any of the first six alignment commands. The letter next to a command name indicates the keyboard shortcut that you can use to align objects. For example, the letter L next to the Align Left command shows that you can press L to align objects with the leftmost point of the object that is used as a reference point.
You can also align all objects with the page center, vertically and horizontally, by pressing P.
To distribute objects
Click
Object
To choose the area over which the objects are distributed, click one of the following buttons in the
Distribute to area of the
Align and Distribute docker:
Selected objects ![](../Shared_graphics/distribute-over-selection.svg)
— distributes the objects over the area of the bounding box surrounding them
Page edge ![](../Shared_graphics/distribute-over-page.svg)
— distributes the objects over the entire drawing page
4
To distribute objects horizontally, click one of the following buttons:
Distribute left ![](../Shared_graphics/distribute-left.svg)
— evenly spaces the left edges of the objects
Distribute center horizontally ![](../Shared_graphics/distribute-center-horz.svg)
— evenly spaces the center points of the objects along a horizontal axis
Distribute right ![](../Shared_graphics/distribute-right.svg)
— evenly spaces the right edges of the objects
Distribute space horizontally ![](../Shared_graphics/distribute-space-horiz.svg)
— places equal intervals between the objects along a horizontal axis
5
To distribute objects vertically, click one of the following buttons:
Distribute top ![](../Shared_graphics/distribute-top.svg)
— evenly spaces the top edges of the objects
Distribute center vertically ![](../Shared_graphics/distribute-center-vert.svg)
— evenly spaces the center points of the objects along a vertical axis
Distribute bottom ![](../Shared_graphics/distribute-bottom.svg)
— evenly spaces the bottom edges of the objects
Distribute space vertically ![](../Shared_graphics/distribute-space-vert.svg)
— places equal intervals between the objects along a vertical axis
Top row: Options for distributing objects horizontally. 1) The Left option evenly spaces the left edges. 2) The Center option evenly spaces the center points. Bottom row: Options for distributing objects vertically. 3) The Top option evenly spaces the top edges. 4) The Center option evenly spaces the center points.
To distribute objects by a specified distance
Click
Object
In the
Align and Distribute docker, click the
Object spacing button
![](../Shared_graphics/distribute-by-object-spacing.svg)
4
Type values in the
H and
V boxes.
5
To distribute objects horizontally, click any of the horizontal distribution buttons.
6
To distribute objects vertically, click any of the vertical distribution buttons.
To align an object with the pixel grid
To view the results, click
View
Pixels, and adjust the zoom level to 800% or higher.
Click
Object
In the
Align with Pixel Grid.
The object bounding box is aligned with the pixel grid.
![*](images/note.svg)
The Align with Pixel Grid feature works with basic curves and shapes. It is unavailable for complex objects and effects such as symbols, text, symmetry groups, vector effects, and PowerClip objects.
