Change content locations
Images, fills, fonts, image lists, photo frames, trays, and templates are saved to your Documents\Corel\Corel Content\[Content Type] folders. You can change the location of some or all these content files by browsing to different folders. For example, you can choose to save templates and fonts to a new location, but leave other content files in your Documents\Corel\Corel Content folder.
When you change a content location, you can choose to move the content files from the old location to the new location.
You can reset individual or multiple content locations to their default folders from the Options dialog box. Alternatively, you can reset all content locations when you reset the application to its default settings by holding down F8 during startup. With this method, all files saved to custom locations remain in place. To restore your custom content locations, you must browse again to the respective folders.
To change a content location
Back to Top
1 Click Tools Options Global.
2 Click File Locations.
3 Click the location that you want to change, and click Edit.
4 In the Select Folder dialog box, navigate to the folder you want.
If you want to move the content files saved to the old location to the new folder, click Yes in the Move Content dialog box.
You can also
Reset the location of a single content type
Click the content type name, and click Reset.
Reset the locations of multiple content types
Holding down Ctrl, click the content types you want, and click Reset.
An icon appears next to content type folders in the Options dialog box when CorelDRAW is unable to find a content folder location because they have been moved, renamed, or deleted, or the external drive is disconnected.
