Customize the status bar
The status bar displays information about selected objects, such as color, fill type, and outline. The status bar also shows the current cursor position and relevant commands. In addition, it displays document color information, such as the document color profile and color proofing status. You can customize the status bar by changing the information that is displayed and by resizing it. You can also customize the status bar by adding, removing, and resizing toolbar items. In addition, you can restore the status bar to its default settings. You can also place the status bar at the top of the application window to see the displayed information more easily.
To change the information the status bar displays
Click the
button next to the displayed information and choose one of the following options:
Document Color Settings
To resize the status bar
Click
Tools
Options
Customization.
Choose
Status bar from the list.
4
In the
Status bar properties area, type
1 or
2 in the
Number of lines when docked box.
To add or remove a toolbar item on the status bar
Click
Tools
Options
Customization.
Choose a command category from the top list box.
4
Press
Alt and drag a toolbar item from the list to the status bar.
If you want to remove a toolbar item from the status bar, drag the item off the status bar.
To resize toolbar items on the status bar
Click
Tools
Options
Customization.
Click
Status bar, and enable the check box.
4
Choose one of the following options from the
Size list box in the
Button properties area:
To change the position of the status bar
Right-click the status bar, click
Customize
Status bar
Position, and click
Top or
Bottom.
To restore the status bar default settings
Right-click the status bar, and click
Customize
Status bar
Reset to Default.
