Google Web Picture (WEBP)
CorelDRAW offers support for the Google Web Picture (*.webp) file format. This open standard format developed by Google provides lossless and lossy compression for images designed for use on the web.
You can import WEBP files in CorelDRAW or export CorelDRAW files to the WEBP file format. You import WEBP files as you would any other supported file. For more information about importing files, see Import files. When you export a file to the WEBP format, you can choose from several presets to suit your needs. You can also create a new preset from scratch or edit any existing preset and save it as a custom preset. For more information about creating presets, see To save a preset for exporting web-compatible images.
You can choose between two compression methods: lossy and lossless. With lossless compression, images do not lose any quality but are larger in size. With lossy compression, images are smaller in size, but suffer a quality loss. You can control the compression factor for RGB channels by modifying the Quality setting. When using the lossy method, a small factor produces a smaller file with lower quality. A value of 100 lets you achieve the best quality. With the lossless method, the Quality setting adjusts the compression. A small factor enables faster encoding speed but produces a larger file. A value of 100 lets you achieve maximum RGB compression and generate smaller files.
You can also control the ratio between encoding speed, file size, and quality by adjusting the Compression ratio. Lower values produce larger files with lower compression quality, and faster processing time. Higher values produce smaller files with higher compression quality, and slower encoding time.
When exporting to the WEBP file format, you can preserve the transparent background of images.
Images can be resized on export by using the Transformation controls.
To import a WEBP file
Back to Top
1 Click File Import.
2 Locate the folder in which the file is stored.
3 Choose WEBP – Google Web Picture (*.webp) from the list box next to the File name box.
4 Click the filename.
5 Click Import.
6 Click the drawing page.
When importing WEBP files, transparency is maintained.
To export a WEBP file
Back to Top
1 Click File Export.
2 Choose the folder where you want to save the file.
3 Choose WEBP – Google Web Picture (*.webp) from the Save as type list box.
4 Type a filename in the File name list box.
5 Click Export.
6 In the WebP dialog box, choose a preset from the Preset list box in the upper-right corner of the dialog box.
Preset
Description
Low quality WEBP
Using lossy encoding, this preset produces images with small file size, low RGB compression quality, and fast conversion time.
Medium quality WEBP
Using lossy encoding, this preset produces images with medium quality and file size and moderate RGB compression.
High quality WEBP
Using lossless encoding, this preset produces images with maximum RGB compression, larger file size, and slow processing time.
Custom
Lets you specify custom settings
Original
Maintains the original settings of the image
7 Click OK.
You can also
Choose an encoding method
Enable one of the following options:
Lossy
Lossless
Set the compression factor for RGB channels
Choose an option from the Quality list.
Lower values produce smaller files at the expense of image quality. Higher values produce larger files with higher image quality.
Set the ratio between encoding speed, file size, and quality
Choose an option from the Compression ratio list.
Export an image with alpha transparency
Enable the Transparency check box.
Resize a file on export
Set preview options in the Export to WEBP dialog box
