Locking an object prevents you from accidentally moving, sizing, transforming, filling, or otherwise changing it. You can lock single, multiple, or grouped objects. To change a locked object, you need to unlock it first. You can unlock one object at a time, or all locked objects at the same time.
You cannot lock linked objects, such as blends, contours, or text inside an object. You also cannot lock objects within groups or linked groups.
You can also lock an object by right-clicking it and then clicking Lock.
You can also lock an object by clicking the lock icon beside the object name in the Objects docker.
You can also unlock an object by right-clicking it and then clicking Unlock.
You can also unlock multiple locked objects by dragging in the second column in the Objects docker.
