Modify and repair installations
You can also use the installation wizard to do the following:
modify the current installation by adding or deleting components such as programs or product languages
repair the current installation by fixing errors such as missing or corrupt files as well as inaccurate shortcuts and registry entries
Repairing an installation is helpful when you encounter problems in using the application, or when you suspect that the installation is corrupt.
Before repairing an installation, try resetting the current workspace to the default settings by holding down F8 while starting the application. Note that when you reset the workspace, all workspace preferences are reset.
To modify or repair a CorelDRAW Graphics Suite installation
Back to Top
1 Close all applications.
2 On the Windows Control Panel, click Uninstall a program.
3 Double-click the suite’s name on the Uninstall or change a program page.
4 Enable the Modify option or the Repair option in the wizard that appears, and follow the instructions.
Product languages can be selected on the last page of the wizard.
Program features and utilities that are already installed may not appear in the wizard, or their check boxes may appear disabled.
Certain features, such as Copy installation files, cannot be added by modifying your installation.
