CorelDRAW lets you select text to edit specific characters or modify it as an object. For example, you can select specific characters to change the font or select a text object, such as a text frame, so you can move, resize, or rotate it.
You can use the Pick tool to select multiple text objects. Hold down Shift, and click each text object.
