Add columns to text frames
To add columns to a text frame
To resize text frame columns
To change the flow of bidirectional text in columns
You can lay out text in columns. You can create columns of equal or varying widths and gutters. You can also apply right-to-left text flow to the columns for bidirectional (bidi) text, such as Arabic and Hebrew (Note that this option is available only for certain languages).
The text in the frame (left) was laid out in two columns (right).
To add columns to a text frame Back to Top
To resize text frame columns Back to Top
Click the Text tool . Drag a column side selection handle.
In the Properties docker, click the Frame button to display the frame-related options. Click the Columns button , and type values in the Width or Gutter boxes.
In the Properties docker, click the Frame button to display the frame-related options. Click the Columns button , and enable the Equal column width check box.
To change the flow of bidirectional text in columns Back to Top
The Right-to-left columns option is available only for bidirectional languages, such as Hebrew and Arabic. The proper keyboard must also be installed.
