Add tabs and indents
To modify a tab stop
To add a tab stop
To indent paragraph text
You can modify existing tab stops by changing their alignment. You can also add trailing leader characters, so that dots, or other characters, automatically precede the tab stops. In addition, you can add new tab stops and remove existing tab stops.
Indenting changes the space between a text frame and the text that it contains. You can add and remove indents without deleting or retyping text. You can indent an entire paragraph, the first line of a paragraph, or all lines of a paragraph except the first line (a hanging indent). You can also indent from the right side of the text frame.
To modify a tab stop Back to Top
Click the cell in the Alignment column, and choose an alignment option from the list box.
Click the cell in the Leaders column, and choose On from the list box.
Click Leader Options, open the Character picker, and click a character.
Click Leader Options, and type a value in the Spacing box.
You can also add, move, or delete tab stops on the horizontal ruler at the top of the drawing window. Click to add a tab stop, drag a tab marker to move it, and drag a tab marker off the ruler to delete it. For information about rulers, see Rulers.
To add a tab stop Back to Top
To indent paragraph text Back to Top
You can remove indents by typing 0 in the First line indent, Left line indent, and Right line indent boxes.
You can indent an entire paragraph by typing the same value in both the First line indent and the Left line indent boxes.
