The guides of the baseline grid run across the drawing page and follow the pattern of a ruled notebook. You can display or hide the baseline grid, turn snapping on or off, change the grid color, and set the line spacing. By default, the line spacing is 14 pt. All objects can snap to the baseline grid; only text frames can align to baseline grid. For more information, see Align text to the baseline grid.
To display or hide the baseline grid |
• | Click View ![]() ![]() |
A check mark beside the Baseline grid command indicates that the baseline grid is displayed. |
To set baseline grid spacing and color |
1 . | Click Layout ![]() |
2 . | In the left pane of the dialog box that appears, click Grid. |
3 . | Perform a task from the following table. |
In the Baseline grid area, type a value in the Spacing box.
Type a value in the Start from top box.
Open the Color picker, and choose a color.
To turn baseline grid snapping on or off |
• | On the standard toolbar, click Snap to, and enable the Baseline grid check box. |
