Copy object properties, transformations, and effects
To copy object properties from one object to another
To copy size, position, or rotation from one object to another
To copy effects from one object to another
You can copy object properties such as outline, fill, and text properties from one object to another. You can copy object transformations such as sizing, rotating, and positioning as well as effects applied to an object.
To copy object properties from one object to another Back to Top
Any Transformations and Effects options on the property bar that are enabled are also applied when you copy properties.
You can also copy fill or outline properties, or both, by right-clicking an object with the Pick tool , dragging over another object, and choosing Copy fill here, Copy outline here, or Copy all properties.
You can also copy object properties to a selected object by clicking Edit Copy properties from and clicking the object whose properties you want to copy.
To copy size, position, or rotation from one object to another Back to Top
Any Properties and Effects options on the property bar that are enabled are also applied when you copy properties.
To copy effects from one object to another Back to Top
Any Properties and Transformations options on the property bar that are enabled are also applied when you copy properties.
