Corel DESIGNER (DES, DSF, DS4, or DRW)
To import a Corel DESIGNER file
Corel DESIGNER (DSF) technical notes
Corel DESIGNER (DES) technical notes
You can import Corel DESIGNER files. Files from version 10 and later have the filename extension .des. Files from Micrografx versions 6 to 9 have the filename extension .dsf. Version 4 files have the filename extension .ds4. The .drw filename extension is used for a Micrografx 2.x or 3.x file. Micrografx template files (DST) are also supported.
To import a Corel DESIGNER file Back to Top
Corel DESIGNER (DSF) technical notes Back to Top
Corel DESIGNER (DES) technical notes Back to Top
