Drop caps
To add a drop cap
Applying drop caps, also known as initial caps, to paragraphs enlarges the initial letter and insets it into the body of text. You can customize a drop cap by changing different settings. For example, you can change the distance between the drop cap and the body of text, or specify the number of lines of text that you want to appear next to the drop cap. You can remove the drop cap at any point without deleting the letter.
You can add a drop cap (left) or a hanging indent drop cap (right).
You can preview a drop cap before you add it to a drawing. The changes you make are temporarily applied to the text in the drawing window, so you can see how the drop cap will look when you add it.
To add a drop cap Back to Top
In the Appearance area, type a value in the Number of lines dropped box.
In the Appearance area, type a value in the Space after drop cap box.
Enable the Preview check box.
Enable the Use hanging indent style for drop cap check box.
Disable the Use drop cap check box, or click the Drop cap button in the Paragraph area of Properties docker.
