To adjust the object-export preview
To export a web-compatible bitmap
To resize an object when exporting a web-compatible bitmap
To customize options for exporting a JPEG bitmap
To specify display-quality options for exporting web-compatible bitmaps
To specify color settings for exporting palette-based web-compatible bitmap
Corel DESIGNER lets you export the following web-compatible file formats: GIF, PNG, and JPEG.
While specifying exporting options, you can preview an image with up to four different configurations of settings. You can compare file formats, preset settings, download speeds, compression, file size, image quality, and color range. You can also examine previews by zooming and panning within the preview windows.
6. Speed list box
Choosing a web-compatible file format
This table is a quick reference for choosing a web-compatible file format.
Exporting palette-based documents
Palette-based documents, such as paletted GIF and 8-bit PNG, allow individual pixels to retain their exact color value. This lets you control the display of colors in the file when exporting. Palette-based documents also allow you to introduce transparency to a file by choosing a color in the image and making it transparent. For information, see Export objects with transparent colors and backgrounds.
To adjust the object-export preview |
1 . | Click File ![]() ![]() |
2 . | Perform one or more tasks from the following table. |
Click the Full preview button
Click the Two vertical previews button
Click the Two horizontal previews button
Click the Four previews button
Click the Zoom to fit button
Click the Zoom 1:1 pixel button
Click the Zoom to actual size button
Using the Pan tool
To export a web-compatible bitmap |
2 . | In the Export for web dialog box, choose preset settings from the Preset list box in the upper-right corner of the dialog box. |
If you want modify the preset settings, you can change the exporting options in the dialog box. |
3 . | Click Save as. |
4 . | Choose the drive and folder where you want to save the file. |
5 . | Type a name in the File name box. |
6 . | Click Save. |
In the Settings area, choose a color mode from the Color mode list box.
In the Advanced area, enable the Embed color profile check box.
You can choose an Internet connection speed from the Speed list box at the bottom of the dialog box.
You can also export to a web-compatible format by clicking File Export, and choosing a file format from the Save as type list box.
To resize an object when exporting a web-compatible bitmap |
• | In the Transformation area of the Export for web dialog box, perform one or more tasks from the following table. |
Choose a unit of measurement from the Units list box.
Type values in the Width and Height boxes.
Type values in the Width % and Height % boxes.
Enable the Maintain aspect ratio check box.
Type a value in the Resolution box.
Enable the Maintain size check box.
To customize options for exporting a JPEG bitmap |
1 . | In the Export for web dialog box, choose JPEG from the Format list box. |
In the Settings area, choose a quality option from the Quality list box, or type a percentage value.
In the Settings area, choose an option from the Sub-format list box.
In the Settings area, type a value in the Blur box.
In the Advanced area, enable the Progressive check box.
In the Advanced area, enable the Optimize check box.
In the Advanced area, enable the Use document color settings option.
In the Advanced area, enable the Use color proof settings option.
In the Settings area, enable the Overprint black check box.
In the Settings area, open the Matte color picker, and click a color.
To specify display-quality options for exporting web-compatible bitmaps |
• | In the Export for web dialog box, perform one or more tasks from the following table. |
In the Advanced area, enable the Anti-aliased check box.
In the Advanced area, enable the Interlaced check box.
To specify color settings for exporting palette-based web-compatible bitmap |
In the Settings area, choose a palette from the Color palette list box.
In the Settings area, choose a dithering option from the Dithering list box, and type a value in the box.
In the Settings area, click the arrow next to Color palette list box, and click Load palette.
In the Settings area, click the Eyedropper, and then click in the drawing window to choose a color. Click the Add the sampled color to palette button
In the Settings area, choose a value from the Number of colors list box.
In the Settings area, click a color on the color palette, and then click the Delete the selected color button.
You can also add transparency to a palette-based document by choosing a color in the image and making it transparent. For information, see Export objects with transparent colors and backgrounds.
