Fountain transparency
To apply a fountain transparency
To create a fountain transparency
Fountain transparency makes the object fade from one transparency value to another. The fountain transparency can be linear, elliptical, conical, or rectangular.
From left to right: Original object with a linear, elliptical, conical, and rectangular transparency applied.
The application provides a collection of fountain transparencies that you can access. You can browse the available transparencies, search by keyword, mark transparencies as favorites, and sort them. You can also download additional fill packs, which can be used as transparencies. For more information, see Find and view fills and transparencies.
You can create a fountain transparency by adding and removing nodes, and specifying a transparency value for each node. You can also reverse, mirror, resize, or skew a fountain transparency, or apply other transformations.
After you create a fountain transparency, you can save it for future use or share. For more information, see Save fills and transparencies.
To apply a fountain transparency Back to Top
Click the Fill button or the Outline button in the Transparency area of the Properties docker.
Click the Edit transparency button in the Properties docker, and specify the settings you want.
You can also click the Transparency tool in the toolbox, and use the controls on the property bar to apply a fountain transparency.
For information about how to find transparencies in the Transparency picker, see To find, filter, and sort fills and transparencies.
To create a fountain transparency Back to Top
Click the Transparency tool , and double-click the node on the interactive vector handles that appear on the object.
Enable the Free scale and skew check box.
Click the Edit transparency button , and click one of the following buttons:
Click the Edit transparency button, enable the Steps check box, and then type a value in the Steps box.
Click the Edit transparency button, and move the Acceleration slider.
Click the Edit transparency button, and enable the Smooth transition check box.
Click the Edit transparency button, and type values in the Transparency width and Transparency height boxes.
Click the Edit transparency button, and type values in the X and Y boxes.
Click the Edit transparency button, and type a value in the Skew box.
Click the Edit transparency button, and type a value in the Rotate box.
To apply the transparency only to the fill or the outline of the object, click the Fill button or the Outline button .
You can also click the Transparency tool in the toolbox. To adjust the transparency, use the controls on the property bar or the interactive vector handles that appear on the object.
You can also drag colors, which are converted to grayscale, from the color palette onto the transparency nodes. Alternatively, if the Transparency tool is selected, you can drag the colors onto the object’s interactive vector handles .
