Type a value in the Rotate box to set the degrees by which the lines are rotated.
When you edit a hatch fill in the Edit fill dialog box, the changes are applied only to the object selected in the drawing window. Only custom hatch fills created in the New hatch from selected dialog box can be added to a library.
You can also apply a hatch fill by clicking the Interactive fill tool in the toolbox, choosing Hatch fill from the Fill type list box on the property bar, and specifying the properties you want.
y-Origin — lets you set the y-origin for the line. This setting is important if you have more than one line in the hatch fill. The y-Origin value can be used to set the spacing between different lines. For example, to ensure that a new line isn’t positioned directly over an existing line, type a new value in the y-Origin box.
x-Origin — lets you set the x-origin for the line. This setting is effective when you have more than one dashed line and you want to offset the patterns of the different lines. It has no visible effect on standard solid lines.
8 .
In the Line angle box, type a value to set the angle of the line.
9 .
In the Shift box, type a value to offset each instance of a line.
In the Hatch lines list, click the Eye icon to the left of the line name. When the eye appears closed, the line is hidden. When the eye appears open, the line is displayed.
