Manage and apply default object properties
To edit default object properties
To set the current style settings as the new document defaults
To apply the default object properties to an edited or imported object
The default object properties in Corel DESIGNER control the appearance of text and graphic objects in the active document. For example, when you install Corel DESIGNER for the first time, each new graphic object has a black outline and no fill by default.
Using the Object Styles docker or the Change Document Defaults dialog box, you can modify the default properties of the following types of objects:
The Change Document Defaults dialog box comes up each time you choose a control that lets you change fill, outline, or text properties when there are no objects selected in the drawing window. If you don’t want to change any default object properties, click Cancel.
When you modify the defaults, Corel DESIGNER automatically saves these changes to the current document. If you want to use the custom settings in subsequent documents that you create, you can set them as the new document defaults.
You can specify which object styles, style sets, color styles, or default object properties in the active drawing are set as the new document defaults.
You can apply the default object properties to edited or imported objects.
To edit default object properties Back to Top
You can also modify the default object properties while editing any object in the document window. Right-click the Default Object Properties folder in the Object Styles docker, and choose Update Default Properties When Editing Objects. Any change you make to an object becomes the default setting for new objects.
To set the current style settings as the new document defaults Back to Top
You can also save settings as the default settings for new documents by using the Options dialog box. For more information, see Save and restore defaults.
To apply the default object properties to an edited or imported object Back to Top
