Manage fills and transparencies
To update the list of fill packs in the Fill and Transparency pickers
To update the list of aliases in the Fill and Transparency pickers
To manage fills and transparencies
The Fill and Transparency pickers let you manage the list of your local packs and aliases (links to local folders, network locations, and secondary storage devices). For example, you can rename the local packs or aliases, and you can remove aliases from the list. If an alias no longer works because the fill folder has been moved, you can browse to the new location to restore the link.
To find the fills and transparencies you like with ease, you can mark them as favorites. In addition, you can view and change the properties of a fill or transparency. For example, you can change its name and language; and you can add new tags and delete existing tags. When you no longer need a fill or transparency, you can delete it.
To update the list of fill packs in the Fill and Transparency pickers Back to Top
Click Rename, and in the Rename dialog box, type a name in the Name box.
Click Open folder location.
Click Open folder location. Select the folder that contains the pack in Windows Explorer, right-click it, and click Delete.
To update the list of aliases in the Fill and Transparency pickers Back to Top
Click Browse, and navigate to the folder that contains the fills.
Click Remove.
Open the folder in Windows Explorer
To manage fills and transparencies Back to Top
Right-click a thumbnail, and click Favorite.
Right-click a thumbnail, and click Properties. In the Properties dialog box, do any of the following:
Right-click a thumbnail, and click Delete.
This procedure applies only to vector patterns, bitmap patterns, and fountain fills and transparencies.
