Managing object data
To choose a database template
To add or edit data for an object
After creating all the data fields you want for a drawing, you can create a database from a template. The database stores all the data you apply to the objects in your drawing. You can choose from three different templates; because each template saves to an external, tagged XML file, you can store the data for different workflows simultaneously.
The Object Data docker provides all the commands and features you need to add, edit, and delete object data — even behaviors that were applied using the Internet toolbar.
You can use one object’s data entries to update another object’s data entries. This function does not replace an object’s data entries; rather, it appends fields and data where appropriate.
Corel DESIGNER also provides common ActiveCGM, WebCGM, and WebCGM S1000D fields. When you import or export CGM files, the object data is maintained. For more information on importing and exporting CGM files, see Computer Graphics Metafile (CGM).
Object data is also maintained when you import or export SVG files. For more information about importing and exporting SVG files, see Scalable Vector Graphics (SVG).
To choose a database template Back to Top
You can also view all existing database entries by choosing All from the list box.
To add or edit data for an object Back to Top
Click the Show/hide behaviors button .
Click the Show/hide data button .
Click the Show active fields only button .
Click the Copy data from button , and click the object from which you want to copy data.
Click the Clear all fields button .
