Modify and repair installations
To modify or repair a CorelDRAW Technical Suite installation
You can also use the installation wizard to do the following:
Repairing an installation is helpful when you encounter problems in using the application, or when you suspect that the installation is corrupt.
Before repairing an installation, try resetting the current workspace to the default settings by holding down F8 while starting the application. Note that when you reset the workspace, all workspace preferences are reset.
To modify or repair a CorelDRAW Technical Suite installation Back to Top
Program features and utilities that are already installed may not appear in the wizard, or their check boxes may appear disabled.
Product languages can be selected on the last page of the wizard.
Certain features, such as Copy installation files, cannot be added by modifying your installation.
