The PaintBrush (PCX) file format is a bitmap format originally developed by the ZSoft Corporation for the PC Paintbrush program.
To import a PaintBrush file |
1 . | Click File ![]() |
2 . | Locate the folder in which the file is stored. |
3 . | Choose PCX - PaintBrush (*.pcx) from the list box next to the File name box. |
4 . | Click the filename. |
5 . | Click Import. |
6 . | Click the drawing page. |
To export a PaintBrush file |
2 . | Locate the folder in which you want to save the file. |
3 . | Choose PCX - PaintBrush from the Save as type list box. |
4 . | Type a filename in the File name list box. |
5 . | Click Export. |
6 . | In the Convert to bitmap dialog box, adjust the width, height, resolution, color mode, or any of the other settings. |
7 . | In the Convert to paletted dialog box, adjust any of the settings. |
PaintBrush (PCX) technical notes |
• | Bitmaps may be black-and-white, 16 colors, grayscale (8-bit), paletted (8-bit), or RGB color (24-bit). |
• | Run-length encoding (RLE) compression is supported, and the maximum image size is 64,535 × 64,535 pixels. |
• | These files may contain one, two, or four color planes. |
• | This file format is supported in Corel DESIGNER. |
• | PCX files can be imported if they conform to the following PCX specifications: 2.5, 2.8, and 3.0. |
• | RLE compression is supported and the maximum image size is 64,535 × 64,535 pixels. |
• | These files may contain one, two, or four color planes. Files containing three color planes or more than four color planes cannot be imported. |
