QuickCorrect
To customize QuickCorrect
To customize quotation marks for different languages
To add words to QuickCorrect
To add spelling corrections to QuickCorrect
To undo a QuickCorrect correction
QuickCorrect automatically corrects misspelled words and capitalization errors. You can customize QuickCorrect by specifying which types of errors you want to correct automatically.
In Corel DESIGNER, the quotation marks that are applied to text vary according to the language that you have selected. You can further customize the quotation marks for different languages by using QuickCorrect. For example, you can change the style of double, single, and straight quotation marks for a language.
Adding words to QuickCorrect lets you replace words and abbreviations that you often mistype. The next time you type the misspelled word, QuickCorrect corrects the word automatically. You can use this feature to create shortcuts to frequently used words and phrases. For example, you can store the phrase "for your information" under the abbreviation "FYI" so that each time you type "FYI" followed by a space, it is replaced with the phrase.
You can have QuickCorrect add corrections made with the spelling checker to its word list so that the next time you misspell the word the same way, it is automatically corrected.
You can also undo a QuickCorrect correction.
To customize QuickCorrect Back to Top
The Correct two initial, consecutive capitals option doesn’t make a change when a capital letter is followed by a space or period, or if a word contains other capital letters.
Instead of enabling the Capitalize first letter of sentences check box, you can change the text case to sentence case. For more information, see To change the capitalization of characters.
To customize quotation marks for different languages Back to Top
Enable the Change straight quotes to typographic quotes check box.
Enable the Use straight quotation marks after numbers check box.
Choose a quotation mark style from the Open and Close list boxes located below Single quotes, or type a character in each of the boxes.
Choose a quotation mark style from the Open and Close list boxes located below Double quotes, or type a character in each of the boxes.
Straight quotation marks are sometimes used to represent feet ( ' ) and inches ( " ).
To add words to QuickCorrect Back to Top
You can use this feature to create shortcuts to frequently used words and phrases. Type the abbreviation in the Replace box, and the word or phrase in the With box.
To add spelling corrections to QuickCorrect Back to Top
To undo a QuickCorrect correction Back to Top
