A texture fill is a randomly generated fill that you can use to give your objects a natural appearance. You can use existing texture fills, such as water, minerals, and clouds. You can change the colors of a texture fill. Texture fills can hold only RGB colors; however, other color models and palettes can be used as a reference to select colors. For information about color models, see Color models.
You can change the tile size of texture fills. Increasing the resolution of a texture tile increases the accuracy of the fill. You can also specify exactly where these fills begin by setting the tile origin. Corel DESIGNER also lets you offset tiles in a fill. Adjusting the horizontal or vertical position of the first tile, relative to the top of the object, affects the rest of the fill.
You can also rotate or skew the fill, adjust the tile size, and change the center of the texture.
To apply a texture fill |
1 . | Select an object. |
2 . | Click the Interactive fill tool |
3 . | Choose a texture library from the Texture library list box. |
4 . | Choose a texture from the Fill picker. |
If you want to edit the texture, click the Edit fill button |
Click Transformations, and click the Mirror tiles horizontally
Click Transformations, and type values in the Fill width and Fill height boxes.
Click Transformations, and type values in the X and Y boxes.
Click Transformations, and type a value in the Rotate box.
Click Transformations, and type a value in the Skew box.
Click Transformations, and click the Row offset
Click Transformations, and enable the Transform with object check box.
Click Texture resolution and size, and type a value in the Bitmap resolution box.
Enable the Fill winding check box.
