When you start a document from a template by using the File
New from Template command, Corel DESIGNER formats the page according to the page layout settings in the template and then loads all objects and template’s styles into the new document. With this method, you can search and browse for templates.
If you want to use only the styles from a template, you can create a blank document by using the File
Open command.
You can also import styles from a template into a document at any time.
For information about searching for templates, see To find, filter, and sort templates.
You can also start a document from a template by clicking File
Open, locating the template, double-clicking it, and enabling the New from template option in the Open dialog box. If you want to use only the template’s styles, disable the With contents check box.
Only the template styles are imported. Page layout settings and objects saved with the template are ignored. The attributes of existing objects are maintained.
