• | To access geometric information |
• | To display geometric information in the drawing window |
You can access geometric information, such as the length, perimeter, and area of objects. You can also calculate the volume of an object by specifying a desired depth. Object geometric information can be copied to the Clipboard and displayed in the drawing window.
1 . | Select an object. |
2 . | Click Tools ![]() |
3 . | To calculate the volume of the selected object, enter a value in the Depth box. |
To access geometric information about another object, select the object, and click Refresh in the Geometric information dialog box. |
3 . | In the Geometric information dialog box, enable any of the following check boxes: |
• | Perimeter |
• | Area |
4 . | Click Create text to display the copied value below the selected object in the drawing window. |
In the Volume area, enter a value in the Depth box, enable the Volume check box, and click the Create text check box.
In the Volume area, click Reset.
Choose a unit of measurement from the Units list box.
Enter the number of decimal places in the Precision box (minimum 0, maximum 5).
