• | To quickly add bullets to paragraph text |
• | To add bullets |
You can use bulleted lists to format information. You can wrap text around bullets, or you can offset a bullet from text to create a hanging indent. Corel DESIGNER lets you customize bullets by changing their size, position, and distance from text. You can also change the spacing between items in a bulleted list. For more information, see To adjust interline spacing.
Three paragraphs (left) were converted into a bulleted list (right)
You can remove a bullet without deleting the text.
1 . | Using the Text tool |
2 . | Click the Bulleted list button on the property bar. |
To add bullets |
If the Property manager docker is not open, click Window ![]() |
2 . | In the Property manager docker, click the Paragraph button |
3 . | In the Paragraph area of the Property manager docker, click the arrow button |
4 . | Enable the Bullets check box. |
5 . | Click the Bullet settings button |
6 . | In the Bullets dialog box, perform a task from the following table. |
Enable the Preview check box.
Open the Symbol picker, and click a symbol.
Type a value in the Size box.
Type a value in the Baseline shift box.
In the Spacing area, type a value in the Text frame to bullet box.
Type a value in the Bullet to text box.
Enable the Use hanging indent style for bulleted lists check box.
In the Paragraph area of the Property manager docker, disable the Bullets check box.
Bullets are inserted at the beginning of each new line that is preceded by a return.
You can adjust the spacing in between bullets by increasing or decreasing the space before and after a paragraph. For more information, see To adjust the spacing between paragraphs.
