• | To apply a special effect |
• | To add a plug-in filter |
• | To inflate a bitmap manually |
You can apply a wide range of special effects to bitmaps, such as three-dimensional (3D) and artistic effects.
Lets you apply effects from a third-party filter to bitmaps in Corel DESIGNER. An installed plug-in appears at the bottom of the Bitmaps menu.
Adding plug-in filters to Corel DESIGNER provides additional features and effects that you can use to edit images. You can add plug-in filters, and you can remove them when you no longer need them.
Corel DESIGNER automatically inflates a bitmap so that a special effect covers the entire image. You can disable automatic inflation and manually specify dimensions for the inflated bitmap.
1 . | Select a bitmap. |
2 . | Click Bitmaps, choose a special effect type, and click an effect. |
3 . | Adjust any special effect settings. |
1 . | Click Tools ![]() |
2 . | In the list of categories, double-click Workspace, and click Plug-ins. |
3 . | Click Add. |
4 . | Choose a folder containing a plug-in. |
5 . | Restart the application. |
The plug-in appears in the Bitmaps ![]() |
To remove a plug-in filter, click a plug-in folder from the Plug-in folders list, and click Remove.
2 . | Click Bitmaps ![]() ![]() |
3 . | In the Width and Height areas, do one of the following: |
• | In the Inflate to boxes, type the number of pixels that should make up the dimensions of the inflated bitmap. |
• | In the Inflate by boxes, type the percentages by which to inflate the original bitmap. |
4 . | To inflate the bitmap proportionally, enable the Maintain aspect ratio check box. |
To automatically inflate the bitmap to cover the entire image, click Bitmaps Inflate bitmap
Auto inflate bitmap.
