Corel DESIGNER can automatically save backup copies of drawings and prompt you to recover them in the event of a system error.
The auto-backup feature saves drawings that you have opened and modified. During any working session with Corel DESIGNER, you can set the time interval for automatically backing up files and specify whether you want the files to be saved in your temporary folder (the default location) or in a specified folder.
You can recover the backup files from the temporary or specified folder when you restart Corel DESIGNER after a system error. If you choose not to recover the backup file, it is automatically erased when you quit the application.
2 . |
In the Workspace list of categories, click Save. |
3 . |
Enable the Back up every check box, and choose a value from the Minutes list box. |
4 . |
In the Always back up to area, enable one of the following options: |
Enable the Back up original file before saving check box.
Choose Never from the Minutes list box.
Auto-backup files are named auto_backup_of_filename and can be saved in any folder you specify. Backup files are created when you save a drawing. They are named backup_of_filename and are always stored in the same folder as the original drawing.
All open or modified files that are not in the Corel DESIGNER (DES) file format are backed up as Corel DESIGNER files.
You can cancel the creation of an auto-backup file by pressing Esc while a file is being saved.
2 . |
Click OK in the file recovery dialog box that appears. |
If you click Cancel, Corel DESIGNER ignores the backup file and deletes it when you quit the application.
